Originally Posted by 69Mcode440
Does anyone have a cnc program to take the 240 heads to max wedge?
Also need my roller cam repaired. Who could I send it to. It's a Howards..It looks a little rough.
Plenty of competent head porters can open a standard port to MW; doesn't require a CNC program. sawzall
Have you contacted Howard's about the cam? Depending upon the issue, it may not be cost-effective to try and repair it.
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
