Without a diagram I'll assume pin 2 is sensor ground(as it should be) That leaves pin 1 which should show 5v. I'll assume it doesn't....if it did your scan data would show -40F with the IAT disconnected. Chase that wire back to the ECM. A diagram with ECM pinouts will help. Good luck!!
