Originally Posted by Bad340fish
I run a .730ish lift solid roller with a heavy spring on my small block. A recent inspection after 5 years revealed my cam bearings looked horrible. 3 drag weeks, 150-200 passes, and 5000-7000 miles maybe? I just went back with standard but will likely have this engine apart again before 5 years.
What spring pressures are you running? 260-280 on the base and 700-740 on the nose (open)?
