Arrow & circle points to where the spot weld broke on mine, which resulted in an oil leak from the hole behind the baffle only when engine was running. The Milodon version has "real" welds here, not sh!tty little spot welds like a high-school shop class.
EDIT: FWIW, there are two different Milodon "stock replacement" BB oil pans: one is the Street Hemi style and the other has a smaller (4 qt?) capacity.
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
