Originally Posted by 426lloyd
Ok I have the correct converter for the small 273 registry , so I guess I need a small registry flexplate also to fit the 273 crankshaft , correct , does anyone have the correct hole size for the flexplate .
What part of the outside register is the same and that the flexplate registers on that outside diameter do you not understand?
You can reuse your existing flexplate.
