My dyslexia kicked in on the original post I meant it was going to be 12.4 : 1
my bad
It will ONLY see street time and honestly it probably won't get driven too much. I am not opposed to running race gas but if I can avoid it, I will
Thanks guys - all good info!
I don't know what your cam is like but I would certainly be conservative on timing and try it out on pump. If it isn't driven often I am not sure I would run E85 but I have no experience with it.
Cam is Howards solid roller 277/285 .600/.600
That’s a TON of duration for your compression and small heads. Way more than I would run, even in a very racy combo with those heads
