Thanks guys
The pulley looks to be the same size as what is pictured here. It’s way to big to fit a correct for the car belt.
Would a Saginaw lump bolt up to the bracket I have? Did they make those in a similar style to the federal pump? The Saginaw s I had were all later and had the teardrop shape, not even close to a federal in look. Also there is a trw pump that from what I know has a similar shape to the federal.
I want my fair share
