The Magnum and LA are balanced differently. B&M flex plate for the Magnum is 10242. There is a cam snout adapter to run a mechanical the fuel pump with a Magnum cam and LA front timing cover. You need a 45 degree adapter at the bypass hose to run the LA front cover.
Doug
