I suspect he has the wrong choke housing. I believe he needs the one that was flat on top, but probably has one with the slight bulge. If that is right, he needs to lift the carb off the intake about a 1/4" or replace the incorrect parts.
The choices are, the correct choke with the flat plate, or the thicker carb gasket, or the AVS with the extended throttle shafts.
