My car is a 3100 lb 69 Roadrunner and has been as fast as 9.87@137 mph. It's a 1964 block bored 4.310 stage VI early straight plug heads 2.14, 1.81 valves, long connecting rods, 11:1 compression and a DC 590 camshaft 5 degrees retarded . I shift normally at 7800 and it runs 10.00 at 134 to 135. When I beat it up a bit and shift at 8400 it has run its best numbers. Did break a Jesel belt a few years ago and buggered up my heads and it's been a turd running 10.20's ever since. Hoping to get everything back on track this winter.
Hutch
