With a girdle they hold up nicely if you keep the rpm in check. Keep repeating that if it makes you feel better, but that 1/4" thick girdle plate does not hurt anything, nor does it help anything. Feel free to post a FEA simulations to make me see the advantage they provide. Can you post FEA simulations that show they don't help? I'm not sold on girdles either way, but you can't call out someone like that if you can't back up your side of the argument.
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
