If you own a pre 1966 car/truck and you are only grocery getting, then 516 heads are FINE!
My grocery getting days in a Mopar are well and truly over for me...
I love Mopar iron heads and am always happy to spend an hour or twenty on them.
My own bug-bear' with 516 heads is, they ''break through' real easy on the exhausts, even with mild port work... panic violin fan
They have a bad exhaust port and that's how it is... ozbbq
The 'Stan Weiss' Flowchart is mind-blowing and takes some reading!
516 Intakes around 220 cfm which is poor.
No 915 'raised port' flow numbers, but they are basically 'closed chamber 906's.
A very trick 906 intake will get you somewhere near too 300 cfm's...COOLIO...
So if you can get 300cfm with any head you need approx, 75% for the exhaust too...(225 cfm).
There is one set of stock '2.08-1.74' 906 heads with 250cfm flow.
If you can start with those numbers you are onto a winner lol... drive
Carpe diem, quam minimum credula postero, thanx Horace!
There’s no point trying to fix stuff that ain’t broke,,, 'but if ain’t broke',,, you is not trying hard enough...
