I made one out of some scrap steel when I needed to do the engine swap on the 2004 Durango.
I've made some small changes since these pics were taken.
I changed where the front attaching points are to where it uses the bolt holes where the intake bolts on and another bolt that connects it to the timing cover at the center.
I literally put the tab at the center through the slot that normally has the chain coming out of it on the engine hoist boom.
Since the engine sits so far under the cowl I needed to connect it as low as possible on the engine.
I pulled the engine out of the Durango without taking the hood off.
