[Not uncommon for it to throw fluid out the vent and sometimes the dipstick if you add all the oil real quick.
I would just clean it up and monitor.
I am in no way questioning your knowledge and appreciate all the help you provide on this forum. But I am curious as to what would cause the above?
One can only put the fluid in as fast as gravity and the dipstick tube will allow unless of course one is somehow pressurizing the fluid and forcing it in. Even then I'm trying to understand what would cause it to burp the fluid unless of course as previously mentionned the vent in the pump suddenly became plugged which seems unlikely.
![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif)
Again, thank you and Mr. Kunkle for all the help you both provide
