I dont like the 4.15 or larger crank in the B wedge if it's a street engine. The pistons are very short. As a result, as things wear, they will rock a lot. I would not recommend a quench tighter than .040 on them, and the rings (including the all important oil set) will not be as good for nearly as long. So the biggest I'd go is 3.915 stroke. JMO.
Well, art is art, isn't it? Still, on the other hand, water is water! And east is east and west is west and if you take cranberries and stew them like applesauce they taste much more like prunes than rhubarb does. Now, uh... Now you tell me what you know.
