I pulled the needle and seat and found the needle to be stuck. I cleaned it and lubed it a bit and put it back. Still no fuel. I checked the fuel pump once more just for fun and found it was not pumping fuel. Off to exchange it for a new one. Thank you for the needle check idea as well as the other suggestions on the sticky floats. I will update the post with a running 440, (unless the next new fuel pump is poop....)
