I used just a basic system with stock pin type brakes on the front and Wilwood Dynalites on the rear. I love the pedal feel with this combo and a 1 1/16" master cylinder . When I press the pedal soft it stops soft and when I nail it they will pull it down fast. The unsprung weight of the Wilwoods is is about half the weight of the 11" drums. You do have to do the math though for the system to work correctly. There is a chart on the Mark Williams site on choosing the proper master cylinder. I was lucky I had a few different master cylinders on the shelf and found the one that worked great.
I made the switch when I was going rounds with 4 drums and it was getting dicey when hot lapping during time runs.
https://www.markwilliams.com/braketech.htmlGus
