Sodium filled exhaust valves allow for more compression on the same octane.
Another trick for non computer controlled ignition engines - an MSD adjustable ignition knob to retard timing if needed get out of detonation on long grades or pulling heavy loads.
Good free flowing exhaust including headers to keep temps down.
Block heat crossover in the intake to keep temps down.
