We try to have the drag radial car stone cold. Usually about 130 at the end of a run.
Monte
even the oil? or do you heat it?
We warm the car at the beginning of the day and get the oil hot. The rest of the day, we want the water as cold as we can get it. In the process of building a chiller to cool it between rounds. Planning on taking the water pump and radiator out of the car. It only makes about 40 degrees during a run and has no fan now. With the chiller, it won't need the radiator.
Monte
