Cam is a lot larger than the stocker. With a good tune I'd expect it to make more than 400 at the flywheel with headers.
Don't know what the ignition timing is at idle, but it's likely going to want in the 16-20 range minimum. Might need a limiter bushing that MSD doesn't make as well.
