I think if you are going to use it as an alignment rack it would have to be flat and level. Anytime it is moved it should be leveled again. I once used a very expensive laser to level two Hunters that had been moved in an assembly plant. They had to be documented for ISO and MVSS compliance. You don't have to be that accurate. laugh2 but it should be checked.
In theory, there is no difference between theory and practice. In practice, there is.
