1970 would be non adhesive vinyl. FYI, Stretch it a bit while wrapping, when a the end of a wrap, you can either tie it off in a knot or use a bit of shrink tube ( be careful with the heat )
That's correct. Sometimes the ends were "finalized" with a narrow strip of cloth adhesive tape.
