I like it (A LOT)……especially with the hood open.
Got to love the way you’ve got to snake the steering shaft around the old HEMIs (that’s pretty much the same routing I had to do on my 37 and I’ve seen several others that are about the same).
Early 331 ? (1954 maybe…….timing cover kind of gives it away)
More details
As far as PS pumps I’ve done a couple. On the 37 I did a mopar pump, as I said , not sure if it was a TRW of Federal. That one pivots for belt tension and the pump pressure is lower than the Saginaw (GM) pump so it seems to work well with the Mustang II rack. Something like this might work well on your Dodge.
FP 2 by
M Patterson, on Flickr
MB 1 by
T B by
TB 2 by
PS B by
On the 57 I did a Saginaw pump and used a SBC bracket as a starting point. On that setup the pump is stationary and the alternator is used to tension the belt.
HP1 by
HP3 by
HP2 by
HP4 by
Might give you some Ideas.
