Might be able to make a reinforced area in the package tray behind the rear seat. That would give you an attachment point that is only slightly below your shoulders. There should be instructions in the box on how to mount the shoulder belts. The mounting is important since you can injure yourself if they are mounted wrong. Mounting them to the floor is not correct so don't do that.
