And check bleeder " Hex " size if yours are Original USA Mopar you should have the big 5/16 bleeders . If wheel cyl s have been replaced , they are usually 1/4" bleeders . CAREFULLY try to turn bleeder , if it doesn't turn with a small 1/4" ratchet or breaker bar , don't go crazy , it will SNAP right off . drive smear a DAB , NOT a huge BLOB of your favorite brand of never-seize on bleeder threads . makes next brake flush a breeze , and NOT a headache . wrench Ronnie
