It should be a 331 hemi, and is likely not the long bellhousing block. Which means it should have the good 331 heads that a lot of the racers like for their 392 race motors. Heads are probably the most valuable part of the motor.
Value of the rest of the car is likely as cheap as you can get it. Four door cars even of that era just aren't overly desirable to most people.
