The problem is if you want thin rings. You can get .043" but the oil ring is the tough part. I talked to Kevin at Total seal last week. Since its getting sleeved it may move enough that 4.510 may not clean up anyway. Its already at 4.505". .9mm are available in the 4.530". Anyway pistons are ordered. Doug
