I think you'll find that shift rpm won't make much difference in trap rpm.
You'll need to tighten the converter, change the gears or run taller tires. (or make less power)
69 Charger. 438ci Gen2 hemi. Flex fuel. Holley HP efi. 650rwhp @7250 510rwtq @5700
