Originally Posted by larrymopar360
Originally Posted by mopars4ever
Sounds like you may have a bulb out.
Or corrosion in the socket
Well as I said the lights front and rear on both sides do come on but they just stay on.
When I actually did have a blown bulb it just prevented normal operation on that side IIRC.
Should be easy to spot though and luckily the relay wasn’t exactly expensive.
UPS unfortunately was though! whistle
