Wow, that was fast! Thank you on the info, that actually helps a lot. I have a 10:1 440 short block and ported Sidewinder heads and 1.6 roller rockers that should get the lift into the .550 range. I think I might slam that cam in that motor, it should work great with a 3k converter in my Duster with 3.91's....
Originally Posted by an8sec70cuda
https://www.summitracing.com/parts/cca-21-248-4/make/dodge
Comp Cams Magnum series solid FT
The 294S-10 engraved on it gives it away.
Nice hot street/strip cam in my opinion. twocents
