The governor parts all move freely and smoothly. I installed new, cast iron sealing rings on the governor during the rebuild. The area the rings seal upon is some what polished but free from gouges and scratches. Would teflon seals be a good idea?
Next I will drop the pan, remove the VB, and air check the servos and clutches again. Then install different VB, put it all back together and try again.
