I won’t use one again. It was a roller master iswis chain. Not many miles/runs on it. It broke the guide and the flat spring started to chew through the side of the cover. I will just buy the best chain I can find and know it is a maintenance item. Wasn’t a ton of spring pressure either. 130ish on the seat solid flat tappet.
best of 11.24 at 119 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
