Use a brite silver as a base coat and the the Chrome Rustoleum or Duplicolor. The silver base helps with the richness of the chrome. The problem then is to find and aerosol clear as a top coat. Some of the can clears can actually have yellow tints(especially when used over whites or silvers). You'll have to check with the manufacturers.
Thanks for the reply.
A lot of work to strip them and I don’t want to experiment and go through that again .
The former owner used spray can “chrome” and it was tough to get off
