0.050" play on pinion yoke means complete rebuild and inspection for damaged parts. If I were going to use it, I would throw away the gearset. Only exception I can think of is if, for some reason, the yoke was removed, then re-installed finger tight; but for that you had better have a solid history and record of any work. Most probably, though, it's junk. Plus, a cone sure grip is not rebuildable. I am not as negative on the cone type as many people, but, if it's very used, it's not worth using for the short life it may have left.
Robert
AAR 4-speed 3.91, Tor-Red; 70 440 6 pack Roadrunner 4-speed 3.54, Plum Crazy; 68 Formula S conv 383 4-speed 3.23, Electric Blue; 69 Barracuda conv Slant 6 OD4 2.94, 71 B5 Blue; 78 Lil' Red Truck, Red; 70 Challenger S/E. 505 6 pack, Passon 5-speed, 3.55, B7 Blue
