What I do is get the initial, mechanical, and total all dialed in for wide open throttle. Vacuum disconnected. Then hook up the vacuum and street drive it. Test part throttle pulls in various situations with the vacuum advance unrestricted and listen for pinging. Keep dialing it back a little and re-testing until it doesn't ping under any circumstance and you're done. Then disconnect and plug it when going racing.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
I don't regret the things I've done. I only regret the things I didn't do.
"Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
