Was able to get my phone up there and get a pic. I see what I have now, it’s a pretty stout plate that straddles both bolts with a corner bent over each of the bolt heads.
Just got to get something in there to bend the corner down.
Fun.
That's the way I pictured it. The tabs have to be bent back to get the bolts out. That case is heavy and can be a pain in the butt getting the bolts back in. If you are just replacing the seals I would do it in the truck.
