When using movers, inventory the valuable stuff, and at least mark the boxes you put it in, unless you can move it yourself. Last couple of moves I know of using movers, not everything showed up. I've always packed my stuff myself, and have probably moved at least a dozen times that I can recall. Labeling the boxes with the room they should go into cuts down on the time the movers have to spend.
