Tires are on turntables and I'm using Quick Trick alignment tools for measurements.
With the tires on turntables, I dont feel like there are any issues with my current measuring setup. I believe I'm getting accurate information and repeatability. According to my plot, the outer tie rods need to be raised. My current thinking has been, replace the tie rods with rod ends for more adjustability. Then spacers can be used as needed. Havent tried it yet though. I have not measured it in Jounce, since its more of a strip car. The torsion bars are installed and the ride height is set.. Thanks for the tips. If the rod ends dont give me the adjustability I need, then I will start over again. Thanks for all the great ideas!
