Quote: The side gear and hub splines must be aligned on all factory equipped 8 3/4" sure-grips, except for the late '68 model power-locks.
Thanks Cass. Maybe mine is a late '68 Power Lok because when I look in the sides everything looks like its lined up. But I'll make sure the axles go in easily before I install it just to be sure.
