All the 5 spds have an OD 5th gear, it is a .71 ratio.
They are all interchangable depending on what you want to swap with it.
umm nope. V8 and V6 are different transmissons
and they are not overdrive's just 5th gear
Nope. as was posted previously, all 5 speeds in Dakotas would be OD 5th. Probably an AX 15 that year. The New Process A 535 used in '87-89s (maybe a bit longer in years) was not very strong. the AX 15 isn't that great either, but is better. but both are OD in 5th!
