Silversport says the length and mounts are the same, so it's a direct replacement for their TKO kits. You just don't have to cut the transmission tunnel, but I think I read the top of the torsion bar crossmember/brace, needs to be clearanced. I couldn't find the details on that. I thought they machined the TKO so you don't have to do that, but this new design requires it? That doesn't sound right.
