Using a voltmeter, measure between the positive on the battery, and the blue field wire at the alternator. This should be close to 0v. If it's higher, something between the two has higher resistance and is causing the voltage drop, so the alt/regulator are regulating them selves to the proper voltage, causing over-voltage at the battery.
If you ever find yourself in a fair fight, your tactics suck.
