"Dual ignition promotes engine efficiency by initiating twin flame fronts, giving faster and more complete burning and thereby increasing power".
Aviation piston engines have dual plugs; during the engine run up prior to flight it's SOP to switch off one set of plugs, this produces a noticeable reduction in RPM called a "mag drop".
The INTERNET, the MISinformation superhighway
