The conversion heads ARE available. I talk to Eric all the time and I just bought a set for a customer a few months back. They require special rocker arms and the block has to be ground for pushrod clearance. It's not something you can do after the fact.
I have done a few of these and I spec a custom cam too because the exhaust rocker ratio is only 1.4:1.
I would take a set for the right price...My engine guy built an engine with a set a while back, and they make the Hp as they claim they do, but as stated, the block needs some pretty serious work to it.
