I recently did 2 66ish assemblies. The center pin was stuck, not the square pin, though it was stiff. I had to press both out. You will see the spot weld if used. Used smallest diameter fitting the pin would pass through against the bracket. Pressed out. Once it popped it came out on low pressure.
