Originally Posted by Transman
1965 was the first year for the slip yolk on an auto trans. Manual still had ball & trunnion in 65.
You are fine as long as the driveshaft angles are correct. Hemi drag cars back in the day made more torque and power and the B & T driveshafts were fine.
Everything is stock so the angles should be fine. I threw on a kit from Brewer’s.
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
