I "adjusted" the rear brakes on my Daughters 61 Bev/Fury by bolting in a 70 E body drum rear end, problem solved...you think the rear are a PITA, wait until you think you got the front squared away and go out for a drive, after the umpteen adjustment, and seeing how archaic the systems performance is, a front disc swap/rear end swap will be in order
Mike
