Originally Posted by 360view
If you temporarily hook up a DC ampmeter to the fan wires you can monitor whether the blades are blocking airflow.
If the amps significantly drop as you drive at higher and higher speeds the blades are blocking airflow.
Thanks for the suggestion... but wouldn't the amps drop anyway (because the fan is having to do less work at speed, with the ram air coming in)? work
