According to comp, neither will work.
"Always remove inner valve springs from dual valve springs or use low load springs (110-120lbs. seat load and 260-270lbs. open load) in place of higher load springs during break-in. In addition, COMP CamsĀ® offers low ratio break-in rocker arms to give you an additional measure of camshaft break-in protection."
https://www.compcams.com/xtreme-energy-218-224-hydraulic-flat-cam-for-chrysler-383-440.html
