Re: Fast car, slow ET?
[Re: Cab_Burge]
#2808508
08/13/20 03:51 PM
08/13/20 03:51 PM
Posts: 14,514 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
60’ is pretty soft for a car with big tires that goes 140mph. Should be close to a tenth better...... low-1.30’s. Plus, it’s a brick...... which should be negatively impacting the speed(so with better aero it would be even faster...... which would make the 60’ look even worse).
It’s an example of not having the “combo” right.
Converter/cam might be a mismatch....... by the looks of the headers, they probably weren’t used for the dyno test, so that’s an unknown variable. Footbrake or transbrake? Glide?
Since the speed is way down....... if the alleged dyno numbers are correct....... there could be some other issues in the car costing some power.
I have seen this type of situation play out before. Car owner spends thousands on car upgrades(converter, fuel system, carb, etc) to no avail, then has motor dyno tested only to discover the car is going as fast as the hp it produces will go(motor doesn’t have what was expected).
I like to use 90% of the STP dyno power as a point of reference for how quick/fast the car “should” be able to run. Then add in any extra ET correction for tracks at higher elevations(over 1000’ or so).
So, working that backwards, 3000lbs, 140mph...... shows 630hp....... which is 90% of 700hp.
Frankly, with what’s available for BBC parts these days...... if one set out to build a “bracket race” 540....... it would be fairly hard to end up with only 700hp.
If nothing obvious in the car reveals itself, I’d put an engine dyno test pretty high on the troubleshooting list.
If the motor tested at 800hp, then the 90% number I’d be looking at is 720hp....... which “should” be going 146@3000lbs.
Sometimes the simple things can be revealing....... do a compression test and check the lash.
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123 Dealer for Comp Cams/Indy Heads
Entire Thread
Fast car, slow ET?
AndyF
08/13/20 07:19 PM
Cab_Burge
08/13/20 07:22 PM
dvw
08/13/20 07:48 PM
fast68plymouth
08/13/20 07:51 PM
n20mstr
08/13/20 08:30 PM
hysteric
08/13/20 09:31 PM
AndyF
08/13/20 09:27 PM
fast68plymouth
08/13/20 09:58 PM
fast68plymouth
08/13/20 10:04 PM
AndyF
08/13/20 11:09 PM
TRENDZ
08/13/20 11:21 PM
fast68plymouth
08/13/20 11:29 PM
AndyF
08/13/20 11:51 PM
AndyF
08/13/20 11:54 PM
fast68plymouth
08/14/20 12:02 AM
gregsdart
08/13/20 11:53 PM
B3422W5
08/14/20 04:51 AM
AndyF
08/14/20 05:22 AM
DusterKid
08/14/20 11:15 AM
n20mstr
08/14/20 11:30 AM
justinp61
08/14/20 12:35 PM
dvw
08/14/20 01:12 PM
fast68plymouth
08/14/20 01:42 PM
Al_Alguire
08/14/20 02:49 PM
AndyF
08/14/20 07:38 PM
Just-a-dart
08/14/20 08:25 PM
B3422W5
08/14/20 08:59 PM
AndyF
08/14/20 07:47 PM
HardcoreB
08/14/20 07:58 PM
Cab_Burge
08/13/20 10:05 PM
n20mstr
08/13/20 10:25 PM
AndyF
08/29/20 05:34 PM
CMcAllister
08/29/20 07:07 PM
AndyF
08/29/20 07:24 PM
n20mstr
08/29/20 08:07 PM
racerhog
08/14/20 10:15 PM
plycuda
08/14/20 10:29 PM
fast68plymouth
08/14/20 11:51 PM
AndyF
08/15/20 12:57 AM
fast68plymouth
08/15/20 01:51 PM
CSK
08/15/20 02:49 PM
an8sec70cuda
08/17/20 12:10 PM
JD Dart
12/19/20 07:43 PM
AndyF
08/24/20 04:32 PM
fast68plymouth
08/24/20 04:59 PM
AndyF
08/24/20 06:51 PM
tabletop390
08/17/20 03:41 PM
AndyF
09/21/20 03:00 PM
fast68plymouth
09/21/20 05:19 PM
AndyF
09/21/20 09:25 PM
AndyF
12/19/20 05:26 AM
racerx
12/19/20 02:32 PM
fast68plymouth
12/19/20 03:03 PM
AndyF
12/20/20 05:06 AM
dvw
12/20/20 12:25 PM
AndyF
12/20/20 08:02 PM
fast68plymouth
12/20/20 08:51 PM
AndyF
12/20/20 10:48 PM
J_BODY
12/20/20 10:07 PM
Cab_Burge
12/19/20 06:46 PM
J_BODY
12/19/20 10:16 PM
